have an R8 installed, its been in use 2 years with no problems until today
keypad made noise (as if in alarm state) and wouldnt do anything (as if the keypad had no power to it). removed cover form panel and external sounded, as expected, since i couldnt get it into engineer mode. all fuses OK. removed mains and battery and re-connected and all back to normal. then about 2 hours later, same thing. remove all power and restore, and works fine?
because its fairly quiet, i didnt notice what triggered it the first time, but second time it was about 5 seconds after i started welding. could have been the same first time.
the welder isnt new, and has been in use for over a year on the same supply as alarm. there is no major drop in voltage or anything when welder is used (nothing dims or anything)
recently moved which included moving the alarm. its on a different circuit and there has been lots of welding done in the last week with no problems, so i dont think its the welder
Any idea's?
Any idea's?
