I've got a customer who has a Dewalt 1251 radial arm saw which is faulty!
What happens is that when you operate the saw it starts up then the thermal trip in the switch operates and turns it off. After a minute or so you can have another go with the same result.
It's a single phase machine rated 1.1kW, 6.2A...
Motor plate markings 1.45kW, P2 1.1kW, 220-240V, 50Hz, 2800rpm, cos 0.98
Switch - Webber unimat WTN22-555 with a rated current of 5A
The start winding has a resistance of 7.36ohms and the main winding 3.61ohms
On start the clamped current was approx 32A
Now to me the winding resistances (especially the main) is low, 3.61ohms equates to 63A?
Does my "logic" sound right, or am I missing the point?
