ChangeAgent
- Feb 10, 2019
- 7
- 0
I have the following setup in a corridor.
In 3 different locations there is a push switch (it always stays in the same positing) that activates a relay in the fuse box. The relay is rail mounted. This relay in turn, turns on the lights in the corridor.
There are several LED spots (GU10) in the light fixing, that are dimmable.
I like to find a way of dimming the spots by putting a Dimmer behind the relay. Ideally this relay is also rail mounted.
Any suggestions if such a relay exist, and what it is called? I could find nothing so far. And maybe other tips, ideas or insights as to how to do this?
