RCBO for wylex nsb
Nov 30, 2008
930
54
is there an rcbo that will replace this
if there is any idea what the model number is for me to find it. have had a look on net but cant find anything.
cheers
wayne
Have you compared to the new NSB or the one previous? You can get those in RCBO's
I'm sure they are the same fitment
Is there room in the board as that looks like the old breakers in my board I just replaced. It was a metalclad Wylex with nsb mcbs and rcbos wouldn't fit in that board?
Very good point, had a couple of boards that won't fit RCBO's in.
Just for you
The terminals do line up, its just the angle i took the pic
---------- Post Auto-Merged at 22:39 ---------- Previous post was made at 22:38 ----------
On the older boards you cant fit Rcbos in the first few breakers as the neutral block is in the way
The only problem you may find some of the earlier boards I think the neutral connector gets in the way of RCBO's as its a solid link but I think its near to the main switch so if its further along the board you may be OK. Newer RCBO'S fit apart from this.
