martinxxxxxx
- Oct 28, 2009
- 100
- 0
Right then, I had a problem yesterday that had me beat and it is annoying me a lot.
Fully tested an installation in preparation for a new fuse board. This included ir testing between the neutral, live and cpc conductors of all circuits and further testing between the above conductors to the same conductors in the other circuits to ensure all circuits were completely independent from each other no shared neutrals etc.
Plus all of the other tests in GN3. No abnormal results recorded apart from an o/c phase on the up circuit which was traced and rectified, loose connection in socket.
There are 3 ring circuits
Down
Up
Kitchen
Kitchen is fine
If any socket on the Up circuit is used - the RCBO for down trips, but the up circuit stays on and continues to work
If any socket on the down circuit is used the down RCBO trips.
Have checked that the conductors for each RCBO are the correct ones and that they have a near infinite IR from all of the other conductors in the neighbouring RCBO - and they do.
Have checked tightness of all connections to busbars and sequence of fly leads from RCBOs.
If I remove the conductors from the down rcbo and run UP circuits - all operates OK.
And (and here is a big clue that I have not been able to digest yet) if I remove the N and L from the outgoing of the UP the down now works fine.
Baffling that the there is interaction between the circuits when they megger out ok from each other.
Also the RCBOs have been tested with the outgoing circuits removed and go through the test sequence fine no trip at 1/2 both ways and 29ms and 30ms at 30 and 150ma respecttivly
Down
Up
Kitchen
Kitchen is fine
