Property with tt earthing system. Tails go into a 100ma rcd then go about 5 to 6 meter to ccu. (tails travel through the building). Consumer is split board has 100ma Time delay as main switch which feeds some circuits. Then a 30ma rcd which feeds sockets etc.
Would i be correct in assuming that after the meter there should be a switched fuse to protect tails and could the 100ma rcd be changed to a time delay before it hits the consumer then two 30ma rcd's in the consumer unit. Therefore there would be some discrimination. my only thought is that the tails should be protected by a 30ma rcd as they dissapear into the floor and appear again at the consumer unit. Currently when ever the rcd trips within the consumer unit it automatically trips the 100ma one by the meter which is a major inconvenience.
Cheers
Cheers
