Also high integrity which has space for a few Rcbo's ie cooker/immersion heater as well as two RCD'sThat would be unlikely.16th ed CU's (split load) had a main switch that isolated some circuits and also fed an RCD which protected some more circuits.
16th TT CU's had a 100a / 100mA time delay RCD instead of a main switch
17th ed CU's (twin RCD) have a main switch which feed 2 seperate RCD's which protect some circuits each
the simple answer to this is yeshi, just a quick question can an rcd be used as a main switch? for some reason i think Ive heard you cant but not sure now i said it, any help/advice i will be most greatful.
