Installing a bathroom fan.
Current CU has 3036 fuses.
Thinking of the best way to add an RCD to the circuit.
Since the fan will be coming off the lighting circuit, i was thinking mounting a RCD fused spur next to the CU and running the lighting circuit via the RCD spur.
So the whole lighting circuit will be protected, as will the new fan.
Its a flat so only one lighting circuit, so not able to split it so all the lights don't fail if trips!
Any other/better suggestions?
