I would if someone could give me some advice. I have had an issue with my RcdTripping today.i did the usual tripping each trip one at a time until finding which causes the RCD to trip. I located the trip that was causing the problem and after a couple of resets it stayed in. Later in the day it went again but this was a different trip on different circuit. And again later it tripped but a different trip on a different circuit. Could this be the RCD failing? Or could there be an neutral issue qnd could this effect different trips?
Thank jason
Thank jason
