NLD
We woke up this morning to find that the RCD of the main consumer unit had tripped sometime overnight (note: none of the individual circuit breakers had tripped).
With all the circuit breakers switched 'on' the RCD could not be reset, but after isolating each circuit breaker individually the problem circuit seems to be a power socket circuit, which appears to be for the power sockets in the kitchen.
However, we plugged the kettle in one of the other power sockets (ie. not on the kitchen power socket circuit) and as soon as the kettle was switched on it tripped the RCD of the main consumer unit, but again no individual circuit breakers had been tripped.
Obviously, I need to determine whether the kettle is at fault, but other than that any ideas?
