Solarexploits
Unusual installation, I have a solar installation (DIY) with battery backup, it powers a no. of circuits within the house separate to the rest of the mains circuits, so, effectively a lot of the house is off grid. There is an RCD on the mini consumer unit which is powered by the inverter, no mains to this CU. Everything works perfectly until overnight when the battery charger on the inverter is on, it doesn't usually happen when the charger first kicks in at 11.30pm on the cheap overnight leccy, but happens, apparently randomly sometime after the charger is on, if I leave the charger off then the RCD never kicks out. If it kicks out we get awakened by the alarm low battery warning (house alarm, not the inverter alarm) which comes on after around 20 minutes of loss of power. If I then reset the RCD it normally stays in for the rest of the night, it's only ever gone out a 2nd time in one night.
I'm totally at a loss as to what could be causing it to go out, we have various items come on overnight such as dishwasher, washing m/c, tumble drier, EV charger, but the trip doesn't appear to tie in with any of the times these come on.
Any ideas would be welcome
Also, this is going to sound like a daft Q, exactly what trips an RCD, is it that it "sees" a voltage going to earth or to the negative & are there different sensitivities of RCD?
