Sharpend
"It Just Is"
Are you not familiar with the wording of the Regs?How come? Please state why they have never complied. They have been installed in their thousands.
In the event of an earth fault, the earth fault current may be lower than the instantaneous tripping current of the
downstream OCPD. In this case, the upstream RCD will trip and selectivity may not be achieved. Therefore, when
selectivity between RCDs and downstream OCPD is required, RCBOs shall be used and selectivity requirements
according to Regulation 536.4.1.4 shall be applied.
(i) avoid danger and minimize inconvenience in the event of a fault
fuses are still recognised by BS7671 and still installed. maybe not an old wylex 3036 board in houses anymore, but blanket statements of 'fuseboards have not been fitted this century' is simple false. BNO boards are still full of fuses and imo would be considered a 'fuseboard'Fuseboards have not been fitted this century. He clearly said (correctly) it was a consumer unit.
fuse boards seem popular on solar farms oddly enough. Probably for reliability - they are used for control ccts / data links/ cooling fans in the sub stations.fuses are still recognised by BS7671 and still installed. maybe not an old wylex 3036 board in houses anymore, but blanket statements of 'fuseboards have not been fitted this century' is simple false. BNO boards are still full of fuses and imo would be considered a 'fuseboard'
dont be letting boris do any EICR;s there then. he'll be giving them a C1 and calling the electric policefuse boards seem popular on solar farms oddly enough. Probably for reliability - they are used for control ccts / data links/ cooling fans in the sub stations.
