gselectrical
- Oct 13, 2009
- 627
- 0
Is there continuity between RCD1 neutral bar and RCD 2 neutral bar? J
One of the first tests I did, there was nothing there.Is there continuity between RCD1 neutral bar and RCD 2 neutral bar? J
I don't use crabtree but remember reading can't remember where but another sparks had trouble with crabtree gear. Maybe worth changing RCD first and see what happens.One of the first tests I did, there was nothing there.I am starting to feel that there is something wrong with the rcd unit itself.
All tests come out clear, there is no continuity from one bar to the next, and I even tested output from each rcd, everything ok.
I am going there tommoro and I will make notes on what tests I do.
I asked because I have never ever seen this problem before.
I'm going with it being the RCD. Test them both and see what results you get. if nothing shows up on the 'standard' tests, swap the RCDs round in the board and see if it still trips the same one.Just started Batty and its a crabtree
ah missed that.But it worked to start with so not likely.
it has to be connected somehow to the circuit that its reportedly not connected toI'm going with it being the RCD. Test them both and see what results you get. if nothing shows up on the 'standard' tests, swap the RCDs round in the board and see if it still trips the same one.I recently got called to a fairly new house by a regular customer who'd moved. He was having trouble with the Crabtree RCD tripping at random. I tested the RCD 3 times and it showed okay every time. Then it tripped on me despite everything being disconnected. Tested it again and as soon as I did the 50% test it tripped instantly. It was out of warranty so swapped the RCD.
I was curious to the cause, so I opened up the RCD to find it had plastic swarf inside. The edges of the casing showed evidence of machining. Clearly Crabtree were having some problems with the plastic mouldings for the casings and were machining the mating faces, but they weren't cleaning out the swarf properly and it was getting into the mechanism. I was gobsmacked. When I was a Project Manager in the automotive industry, any supplier caught doing that trick would have been flayed alive! I don't trust Crabtree anymore - they've clearly taken their eye off the ball, quality wise. The machining I could live with, but not cleaning out the swarf - it's just so basic!
I'd also had a couple of troublesome Crabtree RCBOs just prior to this too.
It would make no difference, it would suck on reverse polarity as well.I did however find an unrelated fault, the cooker hood was a showroom model that they got at a discount, inside I found a block connector which was wired opposite brown/blue, blue/brown.I assume this is so whilst on show the hood blows rather than sucks so the filters stay clean for resale.
I would have thought reverse polarity, reverse motor!It would make no difference, it would suck on reverse polarity as well.
For DC motors YES,,,I would have thought reverse polarity, reverse motor!
Not on an AC induction motor.I would have thought reverse polarity, reverse motor!
I did a couple of 3 phase compressors a few years ago and making sure that they were going the right direction took a bit of time!I do too many 3 phase get them wrong and they do run a little akward
