S searley Senior Member Joined Sep 12, 2008 Messages 320 Reaction score 0 Sep 14, 2008 #1 if a pure inductor of reactance100ohms is connected across a single phase 230v supply the power dissipated in the circuit will be ? HELP. :_|
S seajayess Senior Member Joined May 28, 2008 Messages 272 Reaction score 0 Sep 14, 2008 #2 Hi 230 Volts divided by 100 ohms = 2.3 Amps 230 Volts multiplide 2.3 Amps =529 Watts is that what you wanted CJS
S searley Senior Member Joined Sep 12, 2008 Messages 320 Reaction score 0 Sep 14, 2008 #3 the answer i got on the sheet is 0w.i can`t work it out at that.unless the answePray sheet is wrong. :|
S seajayess Senior Member Joined May 28, 2008 Messages 272 Reaction score 0 Sep 14, 2008 #4 No it is correct can remember that question bit of a trick question as PURE anything is not possible it is because it is PURE reactance so has NO resistance so produces no power CJS
D DTIL Junior Member Joined Jul 22, 2008 Messages 8 Reaction score 0 Sep 14, 2008 #5 Concur with the answer that pure reactance isn't possible
