Hi, Im new to the game and just trying to get my head around all the rules and regs...
I have heard storys of electricians which walk into a job and say 'i cant touch anything unless i change to cu' which is fair enough if the system isnt up to standard but how far do you go with this?
If i come across for example a system where all circuits are fine apart from a ring main which is in poor condition but the CU isnt protected by an RCD do you replace the ring main or do you say you cant touch it unless you change the CU for an RCD protected unit?
Same situation if you get asked to do work on a final circuit supplied by a 'old fuse wire type' CU do you attend to the required work or say you cant touch it unless the board is changed at the same time?
Sorry if some people think this is a silly question, cheers
