Redishbird2
Hi
I have a 2 person Jacuzzi bath with coloured LED lights and a radio. I want to take this out and replace with a normal bath (no electrics).
Under the bath is a plastic box and inside this is a terminal strip. Obviously to disconnect the bath...the connection can be removed...but what should I do with the main feed wire? How should I cap it off safely? Is it best to shorten the wire or tuck it in the wall for someone to use in the future?
Thanks in advance as I know someone on here will help.
Suzanne
Suzanne
