removing van signage
0151
Feb 21, 2009
116
guys im having to sell my van but i dunno how to remove the stickers or should i leave them on?
if i try and remove them will it leave scratches??
is there a link on how to do it
thx
carl
A pressure washer steam is ideal- our local garage has hot water pressure washers that are great for removing the letters
Then use solvent (like the stuff new windows are cleaned with) to remove any residual glue
Did my Transit with a hair drier a few years back, worked OK. The outline is usually there forever though . Don't leave them on , you don't know who will inherit the vehicle and its your name /phone No. on the side. Could be some rough assed sparkie getting you a bad name .
Deke
Get the van nice and warm, heaters on full for an hour or 2 or open the back doors and fire the blow heater at it for a bit, then use a sharp scraper and some decent solvents. To get rid of the outline you may need to give the van a mop\cut and polish etc...
I did the last van in the middle of winter on the drive and din;t have access to the usual methods as above, I used a scraper, hairdrier and some spray solvent in a bottle from Screwfix. Did reasonably well, van could have done with a mopping after though.
