replacing consumer unit
Re Bettys post
my mate had the same thing this week,,,,,guy had done major work in the house and left the to lights to be fitted no certs anywhere
Andys post
wired up an extension a while back,,,,, customer said do i want this cert for reference !!!
EIC done proper by a D.I.
nice
Now to play devils advocate if he changes LIKE FOR LIKE he could do it?
A new CU is not like-for-like, your changing fuses for MCB's or RCBO's in most scenarios. Therefore, the circuit protective devices have different characteristics so there is a fundamental change to the operating conditions.
Did I raelly write that? Blushing Must have the sober head on at the moment. Need more :Y
If you decided (in a silly moment) to change your kitchen florry light for a five-arm chandelier with dimmer switch, I think this would also be notifiable.
Or certifiable? You choose. :D
personally, i wouldnt even bother getting a MWC book from the van...
A new CU is not like-for-like, your changing fuses for MCB's or RCBO's in most scenarios. Therefore, the circuit protective devices have different characteristics so there is a fundamental change to the operating conditions.Did I raelly write that? Blushing Must have the sober head on at the moment. Need more :Y
Did you mean certifiable as in 'electrically certifiable' or 'fruitcake certifiable'?
Your five-arm chandelier in a kitchen might qualify for the latter! :D
:_| ?:| :eek: perhaps try......... Reg 134.2.1!
ALL work needs appropriate inspection testing & certification! :| ;) :)
Hello bebopswivell.
from a question like that do I take it you are not qualified or a DIY person?
So Spesh, if he is neither of those then what is he mate ??????
{A PLUMBER?????}
not many options left
Ah! Blushing
well done Thoery....Applaud SmileyApplaud SmileyApplaud Smiley
you noticed the flaw in my system...
trying to write proper at 1:47am!!!!!
:coat :| :_|
