Bez
- Nov 1, 2009
- 525
- 0
I'm bored with that row now.I have been asked to install a new ring main and lighting in someones kitchen, which is getting a re-fit. All legit and above board through building control etc.I do not want to accept responsibility for the existing installation circuits, that have been worked upon by the home owner.
My question is: if you remove some socket outlets and remove some lighting points and then terminate the cables into appropriate enclosures, which will not be accecible for inspection, then would you then become responsible for the circuits, which you have removed the accessories from?
Just thought i'de have a go at the original question.
As you are aware you must terminate the cables appropriately, either by the use of blanking plates, or take the cables up into the safe zone 150mm from the ceiling, or better still in the ceiling void if possible. (mechanical protection not a viable option in this instance, as you have to expose the cables to protect them, so you might as well move them)
You have now carried out work to that circuit so in my opinion you now have to include it on the EIC.
Further to this the Building Regulations state, "parts of the electrical installations in the building that were not subject to the work, should be no worse in terms of the level of compliance"
You will probably actually leave it in a safer state than when you started, although I accept your concerns that you will be signing for a circuit that most of which you can't see to inspect.
I think this is where the EAWR steps in with the words, "So far as is reasonably practicable"
It would not be practical to pull the house to pieces to check, cable routes, joist notches etc.
Make your terminations, test it, log it, and make a note of exactly what you have done.
