If you have a mains electric clock it will run backwards. The fridge will get warm and the oven cold. Try itThanks Nick. Is there a way of testing to see if there is reverse polarity on any circuits without checking the wiring at the consumer unit, light, socket etc...?
Does the hair dryer suck and the vacuum cleaner blow? ROTFWLIf you have a mains electric clock it will run backwards. The fridge will get warm and the oven cold. Try it
only when your gf is outDoes the hair dryer suck and the vacuum cleaner blow? ROTFWL
And the television starts transmitting images of you sitting in your lounge out through the aerial.If you have a mains electric clock it will run backwards. The fridge will get warm and the oven cold. Try it
i didnt do anything wrong last time, it was you!Just be nice or GF will have to tell us off again.To OP - reverse polarity is bad and dangerous. If you isolate neutral by mistake then the circuit remains live. You could die. This really isn't a laughing matter.
