Blue Fox
- Dec 12, 2008
- 351
- 1
Hello all,
Just a quick question about safe zones, the safe zone is horizintally or vertically from any accesory and I believe its on both sides of the wall, does this include external walls. The reason I ask is looking at a cable route for an extension to a kitchen, the extension is on the side of the house and am going to break into the existing ring main, fortunatly in the original kitchen there is a socket on the wall where I can drill straight through what was the external wall and into the extension, but the customer doesn't want any sockets on this wall only on the opposite wall internally. Its the same for the return there is a socket at the other end of the current kitchen where I can join back into the ring (the 2 sockets are next to each other in the ring so will just be extending a ring), but is this covered by the safe zones as it is through a double brick formally external wall? Additionally to this they also want an outside socket for the lawn mower if I fit this to the outside of the wall of the extension can I then run the cable internally and poke it through straight into the socket or is this not covered by safe zones as its an external wall?
