WightDiamond
Hi all,
Never posted previously but check in from time to time and have a read, always something new of interest. Anyway been out to customer ,they purchased sauna and then called me in .
Cabin has already been assembled into large out building with small sub board already in place- rcd protected ( lights/four sockets/small pond pump and pond lights) fed from house DB in 3 core 6mm swa-buried!
Property has overhead supply and has earth rod for main house distribution board. House DB has split board 30ma and 100ma main iso. Customer has also had problems with up and downstream rcd's between house and outbuilding(that can be dealt with ok)
Several issues here primarily the sauna manufacturer states heater must not be connected to RCD, i assume heating rods may get pitted or absorb moisture.ok so its special location but its all TT system so I'm thinking the following:-
Can i use present feed in SWA from house if i was to disconnect from present house DB and reconnect to new sub main via Henley blocks from incoming supply, new rod at outbuilding, rcbo's in outbuilding apart from sauna feed in 16amp breaker. The real question is will this method meet the requirement for the SWA feed to be RCD protected?
Thoughts and brickbats this way
WD
WD
