The more expensive???? ]The more expensive cable is manufactured by a part of a group that used to be known as Pirelli.Arguably it's a better quality cable... even though both have BS numbers.
I am due to have a 50m drum of 10mm delivered from a local wholesaler tommorow.....
Applaud Smileyim findnig screwfix isnt as cheap as they should be robbing barstewards![]()
Same parent company I understandApplaud SmileySome bits a still reasonable..
but others are ruddy stooopid!
Bit like B&Q...
stick a couple of low price offers to tempt you in...
then stitch you up left right and centre over everything else!!! X( :|
Same parent company I understand![]()
You pay the extra
Not sure what bit you looked at SL, but:http://www.screwfix.com/prods/20999/Electrical-Supplies/Cable/Twin-Earth/Prysmian-6242Y-2-Core-Grey-1mm-100m-Twin-Earth-Cable
is the 'old' pirelli cable at
surely that cable doesnt comply with BASEC if its only rated 24/23Apoint to ponder2.5 mm T+E
one rated at 24Amps the other at 23Amps
i have seen 22Amp rating
Yeah, not sure why he went for 10mm, OP didn't say anything about the csa ? :|That's 1mm not 10mm![]()
