user 30718
- Sep 12, 2018
- 17
- 2
A new wetroom bathroom is added to a large bedroom.
The only electrics in the bathroom are a 12v extractor fan and a 12v light.
The power supplies are both marked SELV and will be housed in the partition wall with an access hatch to the bedroom. The power supplies will be switched using a remote RF switch (powered by the action of moving the switch).
This means there will only be 12v from SELV supplies in the wetroom.
Water to the wetroom will be supplied through plastic pipes.
The shower is fed from a combi boiler. The shower mixer tap, shower head and pipes are metal. There is also a wash basin.
Will the electrician need to connect an earth bonding cable to the wetroom shower or sink?
I’m asking because I plan to pull the cables whilst the bedroom floor is up. There will be a 1.5 T&E for the electrician to use when adding a fused spur to power my transformers. The electrician will add a new mcb to the fuse board when connecting the 1.5mm T&E.
Many thanks for your thoughts...
