bwestwood13
- Feb 20, 2011
- 1
- 0
Good afternoon,
After scouring the net for hours and looking through hundreds of different threads i have not been able to find an answer to my question so i would really appreciate some advice from the pro's
So the story so far....
I have recently moved into a new build property and i am wanting to set up a sky eye using the existing aerial points.
I have got sky in my lounge at the moment and i am wanting it in the master and 3rd bedroom upstairs.
I have enabled the power from the sky box via the hidden menu thing and plugged in a coax cable from the RF2 output on the box to the aerial point in the wall (Will this work or should i run coax through the house? (Cant really afford this)
I then connect the sky eye to the aerial point in the 3rd bedroom upstairs, but LED doesn't light up. Therefore the power is not getting through. Could this be because i do not have an aerial in the loft? Therefore resulting in a 'break' in a circuit?
Any help would be greatly appreciated! ray
Cheers in advance,
Ben
Cheers in advance,
Ben
