Engagesafetysquint
Hi all.
New to the forum and not really clued up on proper terminology so bear with me.
I want to rig up my new shed with 4 double sockets for items such as battery tool charging,bench top grinder , bench top drill press + small lathe.
I also want a lighting circuit which will power 3x 1200mm LED strip lights.
Problem comes with getting power to the shed.
I need to run 15.5 M from the house consumer unit.
I have used a online calculator that has told me I will need 4mm SWA.
Ok. Now the big question.
Can I run the SWA from a spare 32a mcb in the house consumer to a RCD in the shed with a 32a + 6a mcb.
I want to run the double sockets of the 32a from the RCD in a ring circuit to give me the possibility of adding sockets in the future if needed.
Is this possible, and importantly would a sparky be happy to take on the job as described?
