Should have been a relaxing day.
Evans Electric
TEF LINUX ADMIN™
Sep 15, 2008
23,507
527
Birmingham
Pop round to neighbour's to fit 3 new light fittings. Missus asks how long, hour and a half I say. I'm thinking 3 fittings plus a cuppa and a chat, job done.
Stairs light ,remove pendant, wiring is two red Xgrade cables, no earth. New fittings are metal.
Into loft ,find JB with T/E changing to 6491X and all earth wires cut off, re-connect earths ,rewire to fitting ,all the time being dive bombed by the resident angry wasp .
2nd fitting OK.
Down to hall, that one has a T/E but the E is not an E, so up to small bedroom, drag furniture out , carpet up, floorboards up , feeling fed up now , was looking forward to sitting in garden.
J/B with earths cut off again , Strip it all back, expose the earths , take loop imp, thankfully one of them is actually E , reconnect it all , floors back down , furniture back, fit new fitting in hall , neighbour crosses palm with silver, return Thunderbird to its launch bay, into the shower.
Why do people cut off the earths , they've wired in T/E FFS !!!!
Step out of shower , neighbour rings bell, water is coming through hall ceiling , OOOOOOOh NNNooooo , dash round again , empty room, carpet up, floorboards up, a screw has scraped down the side of a heating pipe and theres a pinhole in it.
Another 3 hours draining down , get all water out of the pipe for soldering ........who needs it .......apologies to neighbour..... that was Saturday gone !!!
a bloody hot saturday prob the last,
sounds like a right pain in the arse day, alls well that ends well i guess.
i think i will always make sure i have some speed fit couplers 22mm and 15mm in the van from now on.
ps if it makes you feel better i spilt very hot coffee all over my thighs today on the way to a job
Sounds like drinking and driving to me TBH
a bloody hot saturday prob the last,sounds like a right pain in the arse day, alls well that ends well i guess.
thats why drink driving is a no go, cause you end up spilling it :^O :slap :coat
did the same thing to a gas pipe too. quick bit of solder and the hole was filled.
Just to clarify (i'm still learning)... solder up the hole rather than splitting the pipe and soldering in a coupler? So far... i havn't pierced a pipe - quickly touching wood here mind.
I've had a joiner put a floor board back down with 4 inch 10's, good fix - through cable. Same place different joiner nail gunned through cable putting studwork up, N-E rcd had half the place off.
it is sometimes possibly to solder over the hole if its small enough, otherwise needs cut and a straight coupler put in. if its on a joist, sometimes easier to cut a section out and put in a new bit with couplers either side of joist
I have repaired gas pipes like this a few times. A small hole can easily be soldered. Just make sure gas is off and I usually turn cooker or gas fire on to purge any gas in the pipe. The main thing is to make sure the area is very clean and plenty of flux.
I replaced an immersion heater once , water back on and a load of pinholes and a split in the top of the ancient cylinder due to the twisting etc, water spraying everywhere !!!
Told the old guy he needed a plumber and a new cylinder, he says can you repair it , I can't afford plumbers. :( So I had to remove the cylinder , clean it all up , soldered all the holes and the split , refitted , no leaks , told him if it starts to leak he must get a new cylinder.
20 years later , (I kid you not) I go to a house to fit a bathroom fan heater , old guy about 90 brings me a cuppa and says " Your soldering's still holding out , it should outlast me now"
Does Admin allow discussions of hot wet thighs, if so should this thread be moderated? I thought you were going to say that something else bad had happened to Thunderbird's fuel pump again Evans?
You can't solder a pipe with water in as the water will dissipate the heat too quickly so you'd still have to drain that part of the system at the very least.
If it's a gas pipe do anything with it at your own risk!
It has been said on here before that if your trade insurance covers you as an electrician you may not be covered for a fire from a blowtorch. Check this.
Push fit connections have come on a long way, that combined with a rotating cutter make it very easy to replace sections of pipe. I have in my shed a couple of these 'just in case'
JG Speedfit Pipe Repair Pack of 2 | Screwfix.com
Just make sure you use inserts on plastic pipe.
