Hi
The problem I have is I accidentally damaged a pipe that takes cold water to the combi boiler. I replaced the pipe but now the shower isn't as hot as and the boiler cuts out after 3 minutes.
The hot water taps work ok and the ccentral heating works too.
If the taps are running the shower will be liuke warm.
If the central heating is switched on the shower will be ok.
But as soon as the tap or heating is switched off the boiler stops heating.
It won't run for long than 3 minutes on it's own.
