markysparky
- Apr 25, 2009
- 39
- 0
Hi
I have just finished testing my fathers house prior to upgrading some circuits and a cu change.
He has a 6mm cable supplying a 9.5 kw shower, When I tested at his pullcord, I noticed greening at the line conductors into the terminals?
The position of the pullcord is 10cm from the side of the shower enclosure.
Is this moisture causing corrosion or arcing? I am inclined to cut ina new iso outside the bathroom?
What is your opinion of pullcords for showers or lighting?
I am looking at adding a fan as well so there wil be a lot to chase out with 2x iso, and a switch.
Found a few interesting things while testing;
1. 30 amp breaker 6mm cable supplying 1 x double skt in kitchen!(must fed from old cooker iso position?) zs0.20
2. cooker fed from 2.5 spur off ring under cupboards into a jb, then into 6mm into dual cooker isolator box with socket on side, feeding cooker in 6mm then skt feeding hob ignition. half way up flex there is a taped connector block!!!!
Dad! Been there 20 yrs at least. zs 0.26 all round ring give or take 0.03.
The other house ring ok results, apart from a few bad readings in two bedrooms for the lighting everthing apart from above ok.
What would u recommend changing?
I am going to def add 3x smokes, 2 timer fans, bad lighting cables, rcd dual board.
mark
mark
