oh yes yes...This is not code-able (is that a word ?) This was discussed here about a week or so ago (Apache can look it up ). There is no mention of shower isolators in BS7671. I have always fitted one and remember being taught the switch must have electrical and mechanical identification of on ( Normally a neon and a flag for a pull cord) This was also recently discussed on the IET Website and the only comment on the 'need' to fit a switch may be the manufacturers instructions. These are not normally available for you to comment on so its a no code for a lack of isolator.
no oven gloves next to it, so they can unscrew the lamps?!any way went to a house once that had no switch to some wall lights.....
always on..
unless they turned off the fuse!!?? :_|
Or maybe someone snipped of the pull cords that use to operate the wall lights :^Oany way went to a house once that had no switch to some wall lights.....
always on..
Nothing in the regs says you got to be able to turn you lights off at a wall switch!!!!
