Hi all! We currently have a standard bathroom light pull switch, with a bathroom fan connected. All was fitted by an electrician. I would like to replace the noisy pull switch with a nice silent one, and have found only one option - a "Dimmable pull switch (quiet)" product ref. 2865 from a website called My Green Lighting. So I suppose I have two questions really:
1) Does anyone know of an alternative simple replacement pull switch (i.e. not dimmable) which is silent?
2) If not... the one highlighted above states "The maximum current capacity of the of the product is 250w and minimum 50w.". The fan stats say Power(W) is between 6.9 and 29W depending on speed - so presumably I need to establish what speed it's currently set to, and then buy a bulb of whatever wattage is required to make it up to the minimum 50W? I'm just thinking that if the fan is on Low mode it's only 9.3W so a >40W energy-saving bulb (if I can even find one) is going to be far too bright. I really just wanted to check that I've understood all of this correctly!
Many thanks,
Haydn
Many thanks,
Haydn
