Andy, the question is the Peak Inverse Voltage..RMS voltage is 0.7071 of peak, so 7.071V
thanks,how did you get to that i had a look at your link but im afraid it all went over my head my brain shuts off when things get too complicatedBlushingAndy, the question is the Peak Inverse Voltage..Not the RMS value..
The answer is 20V
B-)
Look at page 3 of the link (the waveform plot)...thanks,how did you get to that i had a look at your link but im afraid it all went over my head my brain shuts off when things get too complicatedBlushing
so the first rule is to read the question!The rms value of a peak voltage (in this instance 10V) would be 0.7071VHowever, the question asks for the Peak Inverse Voltage, as already stated.
The Godfather
The answer is 20V...can anyone confirm for 100% sure its 10v got exam tomorrow!
2 x 1.414 x 7.071=20vOK, I also found this:Half wave rectifier circuits
As the name implies, half wave AC rectifier circuits only use half of the AC waveform in the rectification process. In other words they allow through one half of the cycle and block the other half. This means that power is supplied, to the output of the rectifier circuit - often the smoothing circuit only over half the cycle and this leaves half a cycle when no power is supplied. Accordingly the voltage across any smoothing capacitor drops over this period as charge is removed from the smoothing capacitor by the load circuit. Accordingly levels of ripple are higher than those experienced with full wave rectification as will be seen below.
The circuits for half wave rectifiers are relatively simple. The rectification process can be achieved using a single diode. It is the simplicity of the circuit that makes the half wave rectifier circuit attractive in many applications. It uses a minimum of components and it is able to provide a voltage quite adequately for many uses.
When choosing diodes for use in AC rectifier circuits, one parameter which is of importance is the reverse voltage rating. This is called the Peak Inverse Voltage, PIV. For a half wave rectifier the PIV for the diode must be at least twice the peak voltage of the AC waveform. The reason for this is that it must be assumed that the smoothing capacitor will hold the peak voltage of the AC waveform. Then as the diode is in the non conducting part of the waveform the AC waveform reaches its peak, the diode rectifier will see this peak on top of the peak voltage held by the capacitor, i.e. twice the peak value of the waveform. It is worth noting that the peak value of a sine wave is 1.414 times the RMS value. Thus the PIV rating for the diode must be 2 x 1.414 times the RMS value of the AC waveform. On top of this it is worth leaving a healthy margin to accommodate any spikes that may appear on the supply line.
