Ahhh the dreaded I know it all because I did 14th editiond grandads!no not at all Greenhornet , I started a rewire for a young couple , there grandad of 70 years of age, and his friend who is a spark , have said you don't need to fit smoke alarms , sockets are too high 450mm , switches are too low 1200mm and my price is expensive etc, interfering old gits basically , so i just wanted to clarify ... and yes i always fit them on my rewires .If anyone has a link , that would be good
cheers
Some LABC's insist on the smoke alarms to be fitted as part of the compliance with a rewire passing building control.Just to make things clear, i always fit smoke alarm systems on rewires.And i may be wrong here but:
I thought the wording of the building reg was 'major refurbishment work' so it boils down to if you consider a rewire in this category.
If i had a customer who did not want a smoke/heat alarm system installed on a rewire without a good reason. i would be questioning their conviction to see the job through.
I assume the couple are happy with your quote. Tell the ******s to mind there own business and get a life.no not at all Greenhornet , I started a rewire for a young couple , there grandad of 70 years of age, and his friend who is a spark , have said you don't need to fit smoke alarms , sockets are too high 450mm , switches are too low 1200mm and my price is expensive etc, interfering old gits basically , so i just wanted to clarify ... and yes i always fit them on my rewires .If anyone has a link , that would be good
cheers
Thought radio linked was also acceptable?yes they are needed with out question... mains powered and interlinked with battery back up....
You may want to start with On Site Guide,no not at all Greenhornet , I started a rewire for a young couple , there grandad of 70 years of age, and his friend who is a spark , have said you don't need to fit smoke alarms , sockets are too high 450mm , switches are too low 1200mm and my price is expensive etc, interfering old gits basically , so i just wanted to clarify ... and yes i always fit them on my rewires .If anyone has a link , that would be goodcheers
it's hereAlso Building regs Approved document B.
(you can download on-line versions of all of the Building regs Approved documents)
