Need help in identifying live wire for LED light
i-need-a-lie-down
Jan 28, 2025
4
blackpool
Hi,
Can someone tell me which wire in this wire is the live one for this LED light.
I am trying to connect an inline dimmer switch (bought on ebay) which needs the live wire to be soldered.
Pics enclosed. Many thanks.
Quite possibly neither, if it is connected to some sort of control box, it is likely to be DC.
Oh! Any idea why the two parts of the wire are coloured differently ? Assumed it had a significance. Youtube has videos of these strip LED lights getting an inline dimmer attached - was hoping I could do that too ! :(
You-tube is full of wanna-be video stars posting semi-accurate info, some of which has very limited value...
You need to know the specification of your specific items..
to know if it is dimmable, and if your e-bay dimmer is compatible, and how it can be connected...
From the info given we would just be guessing at best?
The item in the picture is not something I would want in my house with electricity passing through it, looks a complete piece of tat.
That's a crude and simple version of the normal triac based phase angle firing dimmer, but minus any RFI suppression etc.
If as we suspect the wires to your LED are in fact DC than this will NOT work.
That is meant for table lamps, to go in the power cord to it, and for use with LED lamps that are 240v, ie lamps that are replacements for standard tungsten filament. The cable you showed is DC and probably 12v , so you would need an 240v led driver that is dimmable to control the led things you have bought.
Can you post a link to the item you have bought that may help.
Write your reply...
