It does look interesting, well spotted.
Some on the forum have victron kit and should be able to help more than I can.
IIRC wrt Victron
i) the Easysolar has inbuilt MPPT, battery charge and grid i/o all in one but would not cope with 10kW solar, just checking the specs max AC output is 4kW, max PV input is 5800W, for the biggest version
ii) The Multiplus series can battery charge, do grid i/o, but needs a separate PV inverter.
iii) The Quattro series can battery charge, do grid i/o, take generator input with option to autostart, but again needs a separate PV inverter.
The victron inverters I've found only go up to 450V Voc, so with 24 panels you could need more than one PV inverter
This tool will help choose
https://www.victronenergy.com/mppt-calculatoryou can enter your panel details and it will propose suitable kit
Off top of the head the Victron Smart Solar RS MPPT 450/200 might be suitable, it has 4x MPPT trackers,
Check Voc limits carefully though, some of the bigger units have an MPPT upper limit which is also limited to 8x battery float voltage.
I had a very quick search on the ENA test type register for iconica but couldn't find them, I may just have missed them though.
best of luck with your woes
