- Apr 11, 2022
- 36
- 12
Related issue for me.
I have a 5.8 kWp PV array and a 6kW battery storage. Currently on Octopus Agile Export and Variable Rate Import.
I'm getting a PHEV in January - 18.1kWh battery and will install a Zappi to charge it.
Hot water is gas boiler heated immersion tank in airing cupbboard and is only on for 1 hour a day to provide hot water for my wife and I, so not a high demand.
I'm wondering if it's worth installing Harvi and Eddi at the same time as the Zappi - product info on website talks about ability to use Eddi to dictate battery charging times, but how would that interface with my Solis inverter that currently controls charge/discharge of batteries?
Also, I am considering installing aircon in 2 rooms in 2023 and understand that Eddi can divert solar generated energy to power them - which sounds a good idea, (although I get a good return on Octopus Agile in the summer months )
I'm assuming that if I go ahead with the A/C install then Eddi makes sense, but if no A/C then probably not?
I'd welcome comments/advice (Apologies if I'm hijacking a thread here - not my intention, but a rebuff is welcome if I am
Split from hi-jacked post, to avoid confusion for OP
