Hello.
I'm a newbie on here so hope I'm posting in the correct place and hope someone may be able to offer some advice!
About 3 years ago I had an extension built and had to move two PV panels to accommodate the new roof joining the existing one. I have 16 panels (thin film, installed in 2014) in 4 strings (I think!, there's 8 cables down to 2). I moved the two panels and joined them into the other panels. The array has, in my opinion, worked fine since. Then a couple of weeks ago I noticed the array was not producing any power on the inverter (SMA sunny boy SB2000 HF30).
I asked a local electrician / solar installer to troubleshoot my problem.
He tested the array from the last two T joints, so assuming 2 strings at a time, and identified an imbalance of voltage between the two. He asked if there had been any modifications and I told him I had altered the panels a few years previous but it had been ok until a couple of weeks ago. There followed a lot of tutting and headshaking and telling me I shouldn't have touched them and lucky I didn't burn the house down!!
Fair play...I've got broad shoulders, I can take a telling off (which I did).
His theory is, because there is an imbalance due to my intervention in 2018, that that has probably damaged the inverter. He has quoted me £900 plus vat to put scaffolding up to take the panels off, check for damaged / burnt connectors, re-connect them correctly and if the inverter is damaged another £650 plus vat. I have no problem with the chap, came recommended and has good customer reviews, so no doubt about his credentials. Not sure if its worth doing, just under 2k will take me up to 5 years to get my money back by FiT.
Does each string have to be the same voltage as the other strings?
Can the inverter sense an imbalance when the voltage comes down to 2 cables, surely there is only one voltage when it gets to the inverter?
Could it just be the inverter has packed up?
Would appreciate any advice/opinions on this....thanks.
