https://en.wikipedia.org/wiki/ConfuciusHi binky who is confusious
so does all the solis app readings show gwh and mwh as the consumption values thenFor reasons best known to Confusious, they like GwH, irritates the shite out of me...
It's not unique to Solis, all the manufacturers seem to use these units.so does all the solis app readings show gwh and mwh as the consumption values then
Growatt and Victron dont.....It's not unique to Solis, all the manufacturers seem to use these units.
I have ONLY seen these onesI haven't seen those
Mine says:-Device information
Type
Embedded Ethernet
SN
-----------039
Firmware version
ME-121001-V1.0.6(202002111118)
Current time(Time zone)
Sun Mar 26 2023 22:55:37 GMT+0100 (British Summer Time)
do you know if this is upto date firmware on the data logger
WifiJohn is yours Wifi data logger or lan logger
It seems absolutely fine, we do have good WiFi here and stream to TV's etc at the same time, no issues.and how do you find the wifi connection to it sending information out quick or not
Top-right hand side shows as MwhOn your app does it show import as Mwh Gwh or Kwh same for export as mine shows Mwh and Gwh
hi binky is it normal then solis using the mwh and gwh units instead of kwh or do i need to change or setup somethingI haven't seen those
It's only units of measure, SMA do the same. Personally I've always found it very irritating, you install a 4kw system and expect it to produce around 4000kwh a year , and then some twot decides to show the figures in GwH...hi binky is it normal then solis using the mwh and gwh units instead of kwh or do i need to change or setup something
