Mrjmegson
I'll start by saying sorry for this question.
Some things just don't make sense to me.
My batteries came today. Yay. They came with battery cables, the type used with Pylontech, so seriously thick ones, and they also sent me a few meters of what I think is 12mm² cable, which I assume they intend for me to use between the battery disconnect and inverter, however, the inverters use MC4s to connect the batteries, which only take a max cable size of 6mm², so these cables don't fit at all.
Anyway, with this cable dilemma, I decided to work out what size cable I needed. This is how I went about it.
The max charge/discharge rate of the batteries is 50A, as I'm connecting them in parallel, this increases the Amps, which I took to mean, 5 batteries connected in parallel at 50A a battery, would mean 250A, at 51V. So when I put that into a cable calculator, it said I needed 70mm² cable.
So that's clearly not right.
Can someone try to explain this to me?
