pewe
NozSpark
I don't have enough technical expertise to disagree with you, but did you read what Horstmann said when I spoke to them?
They said that a spike from a faulty element appeared to have destroyed both 'circuits' - they never used the word 'switches'.
The switches may still be intact (I haven't stripped it down to see) but sufficient components were damaged to the point where the timer will not work ,
I took the top cover off the thermostat (it was loose and just slid off) and could see that the contacts were welded.
