ruston
Shims in the ball joints, front brake adjustment, rear hanbrake quadrants and levers, and one of the worst if you did not have the gear-clutch removal and primary gear oil seal. Nackered primary gear ripping the clutch plate to bits; usually requiring new crankshaft or the process started sll over again.Ah yes!......best invention was the convoluted cylinder head bypass hose. I used to keep,a couple of spares in the boot
they had some perculiarities....
rotting under body seam trims due to the electrolytic reaction on the clips....de-seamed mine
battery falling through bottom of box
lower rad hose swap...this awakened my interest in gynaecology
speedo,cable snapping
sliding windows jamming
wire pull door handle
the list goes on
There is much more .. definitely a car you could serve your time on , but I loved them.
