special locatiom?
musicspark
Mar 22, 2009
368
I was recently visiting a friend who was told by their local spark that they could not have a pendant in their toilet.
would i be right in thinking, that since it does not contain a bath or shower, that this is not a special location?
Is there any Zoning to apply to wash hand basin or a shower?
Firstly dont put a pendant in a toilet.......
it will get wet and wont work
no issues with pendants in toilets its ok
you have pendants in kitchens and they contain a sink !!!!
i would tend to put a batten fitting in a toilet anyway
Firstly dont put a pendant in a toilet.......it will get wet and wont work
sorry Theory,
i can't tell whether you're for or against?
batten is no good as the ceiling is too high
Neither can Theo, ;) its one of the Great Myths of the Trade, I've heard it dozens of times.
My M8 who is an excellent sparks , still maintains that you can't put a pendant in a kitchen, its got to be a BH at least.
Its because the firm he did his time with had conjured it up and he just can't shake it off.
Theres a thread full of them somewhere on here.
Toilet = not a special location. I have these sorts of discussions with people all the time.
My step son and partner moved into a new property just before christmas and I'd say the house itself was built early 2009 . I have noticed that in their ensuite a batten holder fitting is positioned on the ceiling at about a metre from the shower cubicle . I thought that this fitting had to be I P rated to at least 44 . There is a batten fitting in the bathroom too . The C U is a M E M and has 1 RCD which again I thought that new boards fitted had to be dual RCD . The house is a 4 bed .
sorry guys
its ok for a pendant in a toilet
heavy day yesterday......
I was recently visiting a friend who was told by their local spark that they could not have a pendant in their toilet.would i be right in thinking, that since it does not contain a bath or shower, that this is not a special location?
As the others have said you are quite correct, a room containing a toilet, (even with a hand basin as well), Is NOT a special location.
You can install whatever will fit!
In practical terms batten fitting or other ceiling mounted type fittings are often used due to limitation of space,
e.g. a pendant with lampshade can 'overpower' the appearance of a small room.
or sometimes the doors swinging open end up knocking the fitting if your not careful.
basically you need the height or width for a pendant to look OK in a toilet/cloakroom type environment..
:coffee
Approx 1m from shower cubicle?
therefore >0.6m from edge of enclosure,
therefore Outside of zones...... no problem then? :|
What are the ceiling heights >2.25m from floor? ?:|
Only need IPX4 IF fitted inside zones 1 or 2!
or...
IPX7 in zone 0
IPX5 if water jets used to clean down surfaces.
Thats reg 701.512.2 page 167
Approx 1m from shower cubicle?therefore >0.6m from edge of enclosure,
or...
IPX7 in zone 0
The ceiling heights from memory are at least 2.25m . I should have looked in the BRB though , just being a bit lazy O) They want to change the fitting anyway so have suggested one that is IP 44 just to be on the safe side . Guinness
Wouldn't the whole fitting need to be above 2.25m too?
Although all the circuits in the house are RCD protected I would still fit an IP44 rated fitting . maybe I'm a bit too cautious but I would feel happy about it but your point about the actual fitting being 2.25 clear from the floor I will get out my regs book and see . :)
