First and foremost I am not an electrician, I just need some simple advice about split phase or single phase supply. I’m building a 4 bed house and have laid a service duct under the block and beam. I have received a quote from SSE to install a split phase electrical supply but they don’t want to run their cable as I had planned. Which means I’ll have to dig up some of the block and beam and it all seems a massive pain in the backside and I don’t really understand it. Here is the what SSE emailed me:
‘’I see on your plan that you have marked a yellow cable route that goes under the building and the across to the cut out / fuse position
Due to the distance to the supply point we need to have some mains cable installed and then a service off that – we wouldn’t install mains cable under or through a building or put it into a duct as that de-rates the cable and also makes it vulnerable to overheating, that is why the 95 wavecon cable should go into an open trench so that any heat is dispersed into the ground
If you look at the plan provided with the quote you will see I have therefore marked a route from the pole then underground between the U shaped area of the building and pot end that with a 20 meter 3 x 35 service off the end. The service can go in a duct from the pot ended 95 wavecon cable to the cut out position inside.’’
So my question is, although my plumber advised split phase because of the air source heat pump, do I really need it? What warrants installing a split phase over just a single phase? How much electricity is too much for a single phase?
