Spon's Estimating Costs Guide to Electrical Works
Voltimax
©CAHAGIYTYHE™
Aug 22, 2008
1,103
6
Does anyone have the very latest edition of this book? I believe it's the 4th edition. If yes, could you please tell me what labour rate Mr Spain is using now?
Many thanks
Brian knows nothing , you only have to look at him .
Old fashioned method is a sheet of A4 , four columns ,break the job down into sections .
So adding a dist. Bd in a factory might be :
Hrs qty cost each cost
1 1 C/tree MCCB 100 TP 75.00 75.00
7 20m 25mmx4core SWA 8.00 160.00
2 2 25mm glands 5.00 10.00
/ 50 cleats/fixings .30 18.00
6.5 1 12way TP Dis.Bd 55.00 55.00
/ 12 C/tree TP MCBs 28.00 336.00 4
5 site visit/ measure /quote - - - - --
So 21 hrs= 3 days so 24 hrs at ,say,25.00 = 600.00
Add up mats , add 20% = 784.00
TOTAL 1384.00 +VAT
These are supposed to be in columns but the forum has pushed them all to the left. I don't know how to correct it.
Sorry about that. I had set it out for each column but when I post it squashes it all to the left. :C
The above is for 1 man doing the job ,which is feasible , 25mmX4c SWA not that heavy ,run it off the drum, clip it,make two ends off and connect, fit a MCCB in a panel Bd., mount a dis. Bd and shove a load of MCBs in it.
:^O :^O:^O
BRIAN would have told you...
If you'd asked...
He knows everything! :C
:x :x:x:x
He is now officially seconded to working at Admins, three days a week sorting out forum bandwidth problems...
do not underestimate the power of young Brian Deke!
:C
The little sod ...wait till he gets in .. hes out on the town somewhere .. rat arsed up Broad St I suppose ...then he phones to picked up ..well I'm off to bed ,hes on his own .
Watch it Deke..............
he'll stick the Taxi fare on your credit card if you don't fetch him!
better wait up till 3:30am me thinks! ]:)
I thought I'd resurrect this thread rather than start a new one.
I happened to be looking through spons today and had a read through the builders work section. Is it me or are those time allowances OTT? 54 minutes for a 25mm wide chase in block!!! I know they're for hand chasing (hammer and bolster), but even if you halved those times, they still seem pretty high.What allowances do you guys make for chasing?
Zee, I have my own method ;)
In general if I know the walls are thermalite block, then I'll allow about 30mins for the chase run and the aperture. If however it's fletin brick or indeed I don't know what the material is (rewire) I'll allow approximately double the former.
I was merely curious as to what allowances others make. As spons is a popular publication I wondered if this was the norm.
