ITS Member Joined Oct 3, 2008 Messages 39 Reaction score 0 Jul 27, 2012 #1 Hello, Do Interlinked Smoke/Heat detectors have to be wired in series or can I spur off? Building control have decided they want more Heat Detectors after I've just finished doing what they originally wanted. ****s.
kme Fridge Keyholder™ Supporting Member Joined Mar 7, 2008 Messages 9,984 Reaction score 0 Location In the office again. Jul 27, 2012 #2 They`re a circuit, like any other - as long as the max Zs complies, (and c.c.c, though I don`t expect it to be an issue in this case) you can do what you like with `em
NozSpark Seaman stains™ Supporting Member Joined May 28, 2008 Messages 12,316 Reaction score 122 Location North Wales Riviera Jul 27, 2012 #3 What grade system are we talking about here? If it's a normal domestic system then you can however if it's a panel system then it may not like it
Evans Electric TEF LINUX ADMIN™ Supporting Member Joined Sep 15, 2008 Messages 23,507 Reaction score 527 Location Birmingham Jul 27, 2012 #4 If Domestic Smoke/heat detectors then yes , tee off if you want . Problem you may have is connecting more than two cables in a detector especialy Aico .
A Adrian Senior Member Joined Jun 28, 2009 Messages 461 Reaction score 5 Jul 27, 2012 #5 you could cut a single dry linner behind the aico, do your connection there
wooly Member Joined Feb 1, 2012 Messages 72 Reaction score 0 Jul 27, 2012 #6 If they're mains interlinked you can. Just been on the aico course and they said they're working on bigger connections! Hip hip......
ITS Member Joined Oct 3, 2008 Messages 39 Reaction score 0 Jul 28, 2012 #7 Thanks everyone. Its domestic. Simples! ut the kettle on
wooly Member Joined Feb 1, 2012 Messages 72 Reaction score 0 Jul 28, 2012 #8 You could save time and put a radio base in if they're Aico as the radio bases have hard wired interconnect. (I don't work for Aico lol)
