johninlondon1
- Feb 4, 2011
- 380
- 0
I was plastering a few walls for a decorator friend in a big house in Dulwich, London (500k plus), I unscrewed the twin S/O and found no earth to the socket and between the socket and the skirting board (3cm) I removed the wallpaper and there was just a hole behind it and there was a plastic connector block connecting the spurred socket to the rfc. There was no insulation from each connection for about an inch or so and the cpc was just connected to the metal socket outlet backbox and not to the socket. I told the decorator that this was dangerous and on completion of the plastering covered the full socket with tape and a written notice that the socket should not be used as there was no earth. As I am not a fully qualified electrician yet, What should I have done, I did not want to remove the CB for the downstairs RFC as all the freezer goods would have gone off. What are my legal obligations in this case and what should I have done? As the client was not there, told the decorator to inform the client that he would require a qualified electrician to resolve the problem.
