no. but if you change the first socket for FCU, you can feed both from it.so can i take a fcu from a spur then feed the socket off that
have you seen the new Wylex PSB design? you can safely get 4 conductors into the terminalsits not frowned upon that muchbut 4 cables in a mcb is a no. but allowed headbang
no link me pls andy.have you seen the new Wylex PSB design? you can safely get 4 conductors into the terminals
PSB is the commercial C / D types. they do fit a domestic CU, but they are physically differentit is a wylex. not sure about the psb
capacity is not the decider surely?water heaters over 20(?) ltr should be on their own dedicated circuit, so you cant spur from it
im sure it goes by capacity. im sure special will be around soon with his almighty knowledge of 7671 if i dont get there firstcapacity is not the decider surely?20a heaters yes?
thats what dp switches are for
waits to learn Guiness Drinkim sure it goes by capacity. im sure special will be around soon with his almighty knowledge of 7671 if i dont get there first
in which case, you can use it for a spurthey have a combi, the imersions gone i think they have turned it to a socket
in which case, you can use it for your new spur
