Stairwel PIR Lights
beatrixtiff
May 18, 2010
23
Hi all,
Taking over 2nd fixing of a stairwell tomorrow and wanted to check I'm correct before I start.
PIR steel box - 4 connectors (2xearth,2xlive,1xSW,2xneutral)
Light - 4 connectors (2xlive,2xneutral,1xSW,2xearth)
The PIR has 3 connections which are SP1, L, N. (SP1 must be the SW correct?)
The light has the following connections - L1,N,E and a 'fused terminal' saying its an unswitched live.
Is the fused terminal the live (permenant feed), yeah?
What is the luminaire, exactly? What is the switching method employed?Bit more info needed, methinks....
There's a L,N,E fed from a Key switch in the main board straight to the top floor of the stairwell and looped down 9 floors.
Hope that makes more sense for you.
