anyone got a wiring diagram for a startrite h250a horizontal bandsaw?
if i wanted to bodge it, yes. but i would rather fix the problem thats stopping it working in the first placecant u just fit a relay to solve the issue.
yesHas it got a bar feed?
never checked transformer supply. or the fuses at the bottomCheck voltage from the control transformer is that okay?Is that some form of trip on the right of the box, or just a switch?
Are those 3 fuse holders right at the bottom below the terminal blocks?
It should be pretty easy to trace out the circuit, but it's a shame the builder hadn't heard of cable number sleeves.
So check those fuses, check there's some voltage coming out of the transformer, then trace it through the estop system.
push in contactor and it does work, so definately a control fault somewhere, just not sure what at the momentDave has just beaten me to the fuses bit, I had not spotted them till after my last post.If you poke in each relay does the corresponding motor work?
If so it is a control fault.
thats what i was expectingYou'll have to trace it out, A1 (and or A2) and go from the coils
