I have moved into a 1980s flat with 5 storage heaters. The flat has Economy 7 elec supply but doesn't have two distinct circuits (day & night) within the flat.
The 5 storage heaters are each connected via DP fused switches and I was considering installing a timer in series with this switch so that each switches on at night and off during the day. Therefore, the heater will charge up with heat during night and release during day and will not be using daytime electricity to heat up my flat.
I then noticed that all 5 heaters are connected via 3 dedicated 16A mcbs in the consumer unit and all of these run through a 100A mcb. This 100A storage heater mcb is just used exclusively for the heaters and the remaining lighting, cooker, ring main etc circuits have a second 100A mcb dedicated to them.
My thought is to hire an electrician to install a single DIN mounted timer switch in series with the 100A heater mcb so that all the storage heater circuits are switched off together during the day.
I can see that there are plenty of 16A DIN mounted timers avail. If I was to use these I would need 3 of them in my consumer unit and there's no space for this. I'd much prefer to have one >48A timer switch which would switch all the heaters on or off together. I have 2 slots free in my MEM 2000 consumer unit at the moment.
Is this feasable?
Is this feasable?
